Manuals and Automatics
By ScottyD423
#247538
So I bought a 2017 SR Turbo about a month ago, 30k on it and I gotta say, whoever put that mileage on there wasn't easy doing it. Pretty sure I need a new clutch, 100% positive I need a Throwout bearing...theres a rattle when letting off the clutch pedal, and it grinds when hitting 3rd above 4k rpms, and EVERY gear is stiff to get into when its warm out, buuuuut I can't seem to find either. Is the dealership really my only option? I'd rather not pay $1000+ for a job I can do myself. I know my warranty will cover any transmission repairs but not the clutch, cause its "wearable" like tires and brakes
By Emanuel
#247565
They won’t cover the clutch but all the components around it they will. I had the same issue at 50k, I would hear more of a crunch going into 3rd on higher than 3.5rpm . If your clutch slips or the car turns on in gear with out the foot down on the clutch then. I would say it’s the clutch ... but if the prev owner was a super newb and just had no regards of when to shift and went up hills while riding the clutch ... then I would probably say the clutch. The issue sounds the master slave , check for leak under the tranny if you see a lot of build up of dirt and grime then I would say it’s a leak ... dealer swapped the tranny and that’ was that.
