Pads, coilover kits, springs and sway bars
By eXcude
#241837
I had this saved in a notepad from when I was going crazy trying to find a set of OEM struts for my B16 Spec-V, I figure someone else may find this info useful somewhere.
These are the Nissan part numbers for the OEM struts, I cross referenced all the trims and found only 2 different sets of part numbers:
Spec-V & SER
E4302ET82B front
E4303ET82B front
E6200ET81B back
E6200ET81B back
All other trims:
E4302ZJ60A front
E4303ZJ60A front
E6200ZJ60A back
E6200ZJ60A back
Retailers will say a strut made for an SER will not fit the Spec-V, but according to Nissan it's the same exact part.
By eXcude
#245014
Front Driver
Front Passenger
Both Rears
I am currently running these and I know they fit, they also look very similar to OEM SpecV struts, although they technically don't fit.
Amazon item numbers (if links stop working):
Front Driver: Sachs 313 238 Strut
Front Passenger: Sachs 313 237 Strut
Rear D/P: Sachs 313 239 Shock
By eXcude
#245018
Nissan certainly pushes you into the loving arms of coilovers, it's a pain in the ass finding the correct OEM SpecV struts w/out going through the stealership.
By eXcude
#246538
bobbychet wrote:has anyone else had problems going thru struts?
I'm about to go on my third pair!
Struts can usually go 50k miles w/out needing replacement, depending on drive habits and road quality of course.
3 sets of struts is about the price of coilovers ~$1,000 and they are more durable, adjustable (you don't need to actually lower if you don't want) and are rebuildable. Unlike struts that just get tossed in the garbage.
By LEN
#248328
I bought mine from Bay Ridge Nissan dealer in New York . My dealer here in Bakersfield, CA wanted $8xx.xx for front struts & rear shocks.
Order Contents:
P/NQuantityPrice EADescription
E4303ET82B1 - $ 139.23
Strut ASSEMBLY. STRUT KIT FRLH. Suspension Strut.
Cartridge and Base of the Suspension Strut Assembly.
E4302ET82B1 - $ 139.23
Strut ASSEMBLY. STRUT KIT FTRH. Suspension Strut.
Order Summary:
2 products , 2 items
$ 278.46Shipping & Handling to CA, USA$ 22.95
Total: $ 301.41
_______________________________________________
This pricing for Rear shocks:
Order Contents:
E6200ET81B2 - $ 66.62/ea.
SHOCK. ABSORBER. bolt. KIT - SH. STRUT.
Shock Absorber.
Order Summary:
1 products , 2 items
$ 133.24Shipping & Handling to CA, USA$ 15.95
Total: $ 149.19
Sent from my SM-G960U using Tapatalk
