By aaronsummers
#141447
Just thought I would share this. I had to go back to the ECU controlling the tune because my neo took a dump. I got it replaced but haven't retuned the car but I took this pic of my a/f's on stock settings.
By aaronsummers
#141452
Yea that's not surprising. B16's run really rich from the factory but I think they do that to compensate for lower fuel grades.
Not a big deal, I'll clean up the air fuels when I start to retune.
By Jarek
#141590
Typical nissan. B15s are the same way.
By Jarek
#141665
KingDNH wrote:Mine was in the high 10s low 11s stock.
I'm sure mine was too, but when I dyno'd my car a couple years ago my Spectre Filter was so restrictive it not only threw a Code, but the dyno could barely get a AFR reading, it was 9's and 10's. I should have left the K&N on that pull.
By RSPECTH V
#142901
aaronsummers wrote:Yea that's not surprising. B16's run really rich from the factory but I think they do that to compensate for lower fuel grades.
Where were you running your AFR at when tuned?
By BlackoutV
#142902
Tuned n/a you should shoot for like 13.1ish.
By RSPECTH V
#142903
BlackoutV wrote:Tuned n/a you should shoot for like 13.1ish.
Thanks I just found this :thumbup:
For NA (naturally aspirated) cars, AFRs should usually range from 14.7:1 at idle and very light throttle, 14:1 to 13:1 at partial throttle, and around 12.5:1 at wide-open throttle.
By aaronsummers
#142932
When it was tuned we set it as close to 12.9 as we could get it under wot. I had the neo set so anything under 50% throttle would just use the ecu to control it and after that would use the neo. Only problem was there was a few time I could go wot at about 2500 rpm and the drive by wire wouldn't let it open the throttle over 50% for a few seconds and the car would run rich for a second then back off when the neo took over but it never bothered me as long as it would go rich and not lean.
By RSPECTH V
#144451
aaronsummers wrote:When it was tuned we set it as close to 12.9 as we could get it under wot. I had the neo set so anything under 50% throttle would just use the ecu to control it and after that would use the neo. Only problem was there was a few time I could go wot at about 2500 rpm and the drive by wire wouldn't let it open the throttle over 50% for a few seconds and the car would run rich for a second then back off when the neo took over but it never bothered me as long as it would go rich and not lean.
Thats why I am liking the Uprev. you can tweek it through the whole RPM range.
wot 2500 rpm will scream now and so on. Problem is I can play with it and play with it. Realy need to take it to the dyno to get it just right.
By aaronsummers
#144460
Oh I can change it all threw the rpm range it's just I would like a way to tune it for load instead of throttle or get a throttle controller to fix the drive by wire issue.
By mdh
#145086
Mine is an 11 afr low end the when I get up in the RPMs it goes down to high 10's
By Man Whore
#145089
yea the QR runs rich from the factory... whether its a b15 or b16
By RSPECTH V
#145114
Mine did run a 10.5 to 11.1. Now I am set at 12.8 I can feel the difference.
By mdh
#145353
Well I was at the track yesterday, and when I woul lightly adjust it toget around a 12.5 afr, I ran a 15.3, then I change it to stock 11.0 tune and I ran the exact same time. I don't notice any difference.
By aaronsummers
#145354
Before when cruising I would be 12s and 13s just cruising. Well this weekend I get a CEL about my lower 02 sensor. I replaced that sensor and now crushing im in 14's! I didn't even know it was bad but it made a hell of a difference.
I also re-tuned my car this weekend also so under wot im about 12.9.
Car feels soooo much better after putting that new 02 sensor in, idles better and everything.
By mdh
#145356
Nice! Yeah my stock tune cruising is around 14-14.5... But when I go wot it goes from 12's low, to 10's high rpm...
By RSPECTH V
#145369
mdh wrote:Well I was at the track yesterday, and when I woul lightly adjust it toget around a 12.5 afr, I ran a 15.3, then I change it to stock 11.0 tune and I ran the exact same time. I don't notice any difference.
I forgot to put in there my timing was changed also. Thats where I am feeling some difference.
Good #s at the track by the way.
By mdh
#145394
Last time I was at the track I ran 15.1-15.2's all day... That was before the bsr chain cut and with horrible shitty tires. I didn't think it was that great of a time, but it wasn't horrible.
