1/8 to 1/4 to bench racing and street racing. All straight fun
#228162
Caution
serious damage to motor, tranny and axles may occur if you engage in this activity
racers only, who understand and are prepared for the risks
only works on slicks to my knowledge
stock flywheel has been used to 5000 rpm BUT
stock clutch will fail rapidly used this way
best done on clutch and flywheel chosen for this activity
my clutch is multiple times harder than the stocker, utilizes a cf disk and a solid steel, 14 lb flywheel
[one of 2js rare drag clutches]
been playing with the idea of using a flywheel motor assisted launch
sit at the line, spin the motor to rev limit
using the rev limiter as a two step
launch, just pop the clutch, yes sidestep it
and BACK OFF the gas, [about 3/4 throttle]
let the slicks wrinkle and catch as the rpms fall
nail the gas
seems to work on both sets of slicks
car is burnout capable now
jumps off the line
no clutch slipping at all
note
preload car to take the slack out of the axles
hold with parking brake
and return clutch to the floor
then launch
saves on axle breakage
looks like at least 2 weeks before vids
rained out this week
photo crew working next week
btw
the use of the flywheel to control the launch is very consistant
it behaves the same way, every time
the inertial spin down is pure mathematical physics
#237247
update
the launch vids are long up
and the real world results were this
the 14lb fltwheel is still lightweight
and does not store enough energy to do a pure flywheel launch
so clutch slipping is still very necessary
as a result the clutch and flywheel ended like this after 3/4 of a season's runs
and thats with the upgraded cf disk and stage 3 pressure plate
[replaced with stage 4 clutch and drag only 6 puck clutch plate]
did survive several high hp nitrous shots
at least it got me home
the flywheel was also replaced with the same 14lb 2jr unit
but a different launch system is now employed
anticipating slipping the clutch
#237525
update
10" tires are too much for the subframe and unibody
at above 300 ft lbs tq
on launch the unibody twists
and the k frame moves
distorting everything
once 0-60 ft times drop to 1.8 or below
a roll cage will help the unibody
but the k frame mounts above 400 hp
imo will be a problem
presently my temp fix
is slipperier tracks and limited to 8" slicks
will try again in late oct
with new heim joints
replacing my 4 year old orig prototypes with the better production items
ImageDSCN0947 by Barry, on Flickr
note new windshield banner
#237653
problem disappeared on the track
the g-tech 0-60ft times were accurate
was able, on one run, to duplicate the 1.8 sec run
fastestest it ran was 7.9s in the 1/8
beating the vq record here by .6 in the 1/8
but i could not duplicate it
ran some mid 8s and even some low nines
went home
too inconsistent in the colder weather [45-50*f]
1st gear was smooth and straight, after that forget it
all over, hopping and bopping ,slipping and sliding
looked good just off the line though
ImageCP4_6451web-(ZF-0665-95524-1-002) by Barry, on Flickr
#237681
after analyzing the data, and studying the pics, i believe this is the sequence of events
launch at higher rpm, 5000
no boost thru most of the 60 ft run
shortly after 2nd gear [shift point was 7000, on the track]
full boost develops
thus its performance in the 330 range
loses traction, dramatically, and begins to hop
while the 60 ft times hover in the 2.1s
the 330ft times are all over the place
learning:
lift, don't press, going into 2nd gear
back peddle 2nd gear
collected data from two other cars running out of 2js shop
verifies the same low traction 1st and 2nd gear on high tq turbo sentras
these two, with much greater hp than mine, were nearly impossible to hook up
even on 9" wheels and 235/40/17, good summer tires
the 275s definitely deliver superior traction
and for now at least a 26" tire is necessary
a 28" diameter tire would be the best
[lowering tq multiplication in the lower gears]
btw
launching under boost may not be a good idea with our limited traction
imo
By ProTo20
#237942
I think you need to look into the NT555R or a bias ply drag tire for best results.
I know a few Honda guys pulling off 1.7 60 foots with the right tire.
You should be in that range easy.
#237978
i was so thrilled by being free enough to go in totally off the street
36psi in the tires
that i am seriously thinking of DRs for next season
i have had good luck with toyo tires
both the R1Rs and the R888s
now they make a DR in 275/40/17
also checked the nittos 555s and 05s
cheap and big enough
http://www.jegs.com/i/Nitto/726/40156/10002/-1
the advantage is the 15" wheel, allowing a much bigger sidewall
these have better tread but less sidewall
http://www.jegs.com/i/Nitto/726/40585/10002/-1
btw
i did get one 1.8 run
lol
i was happy with that time
i was able to beat the vq times on slicks [at this track]
on r888s
7.9 vs 8.5 in the 1/8
those 1.7s hondas should be turning 7.6s in the 1/8
yes?
[very low 12sec 1/4s]
#238258
indeed
now we have developed further mods
i stuck with oem axles for replacement for now
more clutch slipping and the use of the water box to ease load on the axles during burnout
and more clutch slipping on launch
will be tried
this will let us see what the stock axles can actually deliver
By cooper1122
#241018
I'm havingtrouble with pop-ups and new tabs for 'Mackeeper' among others, launching themselves in Safari on my ... You installed the "DownLite" trojan, perhaps under a different name. ... Drag the selected item to the Trash.
What kind of exhaust should I get?
trunbendz is good to Sent from my iPhone using T[…]
I got my annual bonus and wanted to get myself so[…]
Going 140 km/h+ 2012 specv
even on a modified motor things get hot after 5k […]
Fresh meat from NC
welcome looks like a nice clean car to start your […]
