Straight lines dont do it for you? Need some more curves, mmhmm
#241770
under discussion, no real solutions yet
but some findings that relate to tire wear and steering effort
Tramling can be defined as the car shaking its head.
rapid movements back and forth that can be violent
after much experiment and discussion
we find
as wheel width increases, track increases and traction increases
we get to a point of instability
some useful indicators are center of tire rotation and the resulting scrub radius changes
if the tire doesn't rotate on center
one part of the tire must move more than the other side
it scrubs
this affects tire wear as well as tamlining
looking at the following tire, we see its center of rotation is far from center
resulting in the inner edge of the tire scrubbed clean
even though wear every place else is even
Image20161017_153914 by yogib777, on Flickr
center of rotation was determined simply by turning the wheels in place
several times, rolling back a bit and observing the results
as the center of rotation moves toward the outside of the wheel [my case] steering effort increases exponentially
Small changes make big differences
closest solution is brocks short track car
9" wheels, 35mm et, 235/40/17 r-comps
center of rotation moved in about 1/4" from mine
ImageDSCN1606 by yogib777, on Flickr
ImageDSCN1604 by yogib777, on Flickr
compared to mine
Image1309488 by yogib777, on Flickr
ImageDSCN1090 by yogib777, on Flickr
back to 2jr, tomorrow
we try smaller tires on the same wheels
but track tires not street tires
will report back on new alignment specs and track dyno tune
[faster turbo spool, more low end, less top end hp]
real test will be Sat. Nov 5th
can it run wot at AMP
tuned at 361hp, 371 tq, it turned 91mph in the 1/8 mile
shaking so hard, i would not have been able to hold it in lane had it been a 1/4 mile
#241784
next we can illustrate inconsistencies
and general rules
what makes little sense yet:
complaint
car shakes on wot
ans, [camero forum]
front wheels and tires too large
yet in my case
275/40/17 r-comps went straighter
had less shake
than the 255/40/17 extreme street tires
on the same rims
17x9, 20mm et
ImageDSCN0327 by yogib777, on Flickr
but the general rule is backed up by this experiment
we tried an extreme case
a car with stock wheels, 47mm et, and extreme street tires
went straight but spinning with 225s
ImageDSCN1854 by yogib777, on Flickr
substituting 15x8s fitted with 225s of similar ilk
but
with near 0 offset
10mm spacers required to clear the z32 calipers
car goes crazy
ImageDSCN1840 by yogib777, on Flickr
hypothesis
[17"] wheels with less than 20 mm et, MAY cause excessive tramlining and increased steering effort
#241841
next we totaly solved the problem
just run slicks
lol
i had never run slicks on all four wheels before
what a trip
total grip
to the ground goes all the zip
it's a pip
to be able to zip and rip
with just a throttle blip
but takes tires huge, and super light
ImageDSCN2035 by yogib777, on Flickr
and just the right height
ImageDSCN2011 by yogib777, on Flickr
compared to 225s that bite
ImageDSCN1949 by yogib777, on Flickr
but on the car, they look just right
ImageDSCN2040 by yogib777, on Flickr
the ride is outta sight
turns easier and with less might
nail it
wail it
it sits tight
finally got it right
#241842
tramlining what tramlining
you can see from what i wrote, this really works
tq steer is still there, but most of the head shake, wot, is gone
and for the 1st time i can use all the power coming out of corners
turn in, is instant
car feels more neutral mid corner
and corner exits have gone from nitemare to carnival ride
acceleration from 40-100 surprised me
get it to hook and this begins to feel like an 11sec 1/4 mile car
something are readily explainable
it makes sense for the turn in to quicken
we about cut the side wall in half and made it stiffer
decreasing tire diameter, is like increasing gearing
add increased grip
and faster acceleration seems expected
what i could not explain:
why the ride got better
why the steering got easier
why wot was straighter and easier to control
now, how do i duplicate this with tires i can actually drive on the street
as it sits now
i am totally happy with it
if i could use these legally
i'd be starting on the cosmetics for the 1st time
By CrickiKaze
#241844
Tire construction really, stiff sidewalls are more than likely the biggest assistance and the taller tire probably helps with how much flex is being transferred to the steering...only a guess really.
By CrickiKaze
#241845
If those are wet slicks, that will explain a good bit as well to your experince since they heat up faster.
By CrickiKaze
#241847
So what was the whole set up on the rims and tires, I see 19 on the tires in chalk.
2007 Spec V Part Out
Sway Bars? (F)
V2 Intake cams from 2j
i generally run the most rad setup i can get away […]
Find part number 1326897E0A on eBay Source: http[…]
saved for vid running
