#189173
Hey everyone :)
I installed a rear backup camera for my SR and took pics in the process. Anyone interested in a DIY for a backup camera? I connected mine to the reverse light so it turns on automatically when I shift to reverse!
#245485
Troy wrote:Sounds great! I will compile the pics and write the DIY... Should be up by this weekend :)
Hi Troy,
I know it's been more than 5 years since you posted this and I'm not even sure if you are still active on this forum.
However, I believe you may get email notification. So, hoping for the best.
Do you have the DIY steps with you or posted anywhere?
2007 Spec V Part Out
What's up on the coil packs?
V2 Intake cams from 2j
i generally run the most rad setup i can get away […]
Find part number 1326897E0A on eBay Source: http[…]
saved for vid running
