2000-2006
By xbrandonx
#1913
No new pics for in case anyone hasn't seen my spec here are some old ones...
Only pic that isn't over a year old...
I've got a shit storm more pics, feel free to browse my photobucket and cardomain:
http://www.cardomain.com/id/xbrandonx
http://smg.photobucket.com/albums/v323/ ... ar%20pics/
Mod list....(probably not 100% up to date.)
Engine
-Precision 5431 Billet 50 Trim Turbo
-Treadstone Turbo Manifold
-633 Injectors
-JWT Turbo Reflash with 7200rpm Rev Limiter
-Treadstone 2.5" Intercooler Piping and TR8 Intercooler
-Greddy BOV
-Tial 38mm Wastegate
-Treadstone 2.5" Downpipe
-Stromung 3" Midpipe
-Stromung 3" Exhaust
-HKS Circle Earth ground system
-HKS Super AFR
-Hondata heatshield Intake Gasket
-SWA underdrive pulley
-JWT C1 cams
-JWT valve springs
-JWT balance Shaft removal
-NGK Colder Plugs
-Deadened Knock Sensor
-NX single fogger wet system (currently Uninstalled)
-Ported Throttle Body
-ES Motor Mount Inserts
-Koyo Racing Radiator
-210 Flex-a-Lite puller fans
-Optima red top battery
-2J Racing Vacuum Block
-Nismo oil filler cap
-Nismo radiator cap
-Paint matched fuse box covers
-Chromed battery tie down
-Chromed radiator supports
Tranmission
-TWM Performance Short Shift linkage
-FIR Nylon Transmission Bushing set
-FIR Crossmember Inserts
Exterior
-Full Cobalt Blue color change (car was originally black)
-19x7.5" et44 Racing Hart GT-5
-Composite Creations Velocity carbon fiber hood (sold, currently Hoodless, have a VIS OEM carbon Fiber hood on the way)
-Composite Creations World Challenge carbon fiber lip kit
-VIS carbon fiber trunk lid
-custom STI style carbon fiber spoiler
-Carbon fiber fuel door
-Webasto sunroof
-Shaved Door Gaurds
-Shaved and Relocated Antenna
-35% Tint
-Rear Fenders rolled
Suspension
-Chromed and painted front strut tower bar
-Toyo Proxes 225/35/19
-Nismo Rear Sway Bar
-Tein Basic Coilovers
-Powerslot rotors
-Painted calipers
Interior
-Sparco Torino racing seats
-Sparco clubman 3-point harnesses
-Sparco Grip Pedals
-Re-upholster back seats in Sparco Red
-Re-upholster door inserts in Sparco Red
-Re-upholster Sparco Arm Rest
-Sparco Shift boot
-Microsuede Headliner with Spec V embossed in sunroof door
-Carbon Fiber Door sills
-Carbon Fiber Trunk Finisher Plate
-Painted trim
-TWM weighted billet shift knob
-(2) Nismo switch cigarette lighters
-Nismo Floor mats
-Fiberglass gauge pod
-Raptor Performance Shift Light
-Autometer Phantom II Boost/Vacuum Gauge
-Faze Gauge gauges set in carbon fiber located in Glove Box (Volt, Oil Pressure, EGT, Fuel Pressure)
-Faze Gauge Morphers set in Carbon Fiber located in Lower DIN
-Indaglow reverse EL gauges
-Ractive Carbon Fiber Ebrake boot and handle.
Audio
-Alpine 7894 CD/MP3 Player
-JBL P650C 6.5 components
-JBL P652 6.5 coax
-JBL P1220 -12" subwoofer
-JBL P80.4 -4 channel amp
-JBL P180.2 -2 channel amp
-(2) Power Acoustik PT-727MSV mounted in Sun Visors
-PS2 mounted in Trunk with wireless controllers
-Monster Cable wiring
-Monster Cable distribution block
-Black and Decker 400 watt power inverter
-Wireless FM modulator
-Fiberglass/ lexan subwoofer enclosure
-Fiberglass rear deck lid
-Dynamat Extrmeme on door skins
Lighting
-HID Retrofit with E55 Projectors
-Sylviana Silverstar Front Turn signals
-Sylviana Rear Blinkers
-Sylviana Rear Breaklights
-PIAA Ion Crystal Foglights
-Blue Neon tubes in Trunk and Under Seats
I've got a Nismo front sway bar, the alt heat shield and Crown Stainless Steel Brake/Clutch lines that need to be installed.
By Tonez
#1915
Love that blue man! Car looks sick in that color! :thumbup:
By xbrandonx
#2001
duesmandella wrote:I have always loved this car
Brandon what 15 inch wheels are those? do you still have them? are they 4x100 and 4x114.3?
I added this to your profile
Cheap...brand is Ricochet. I got them with drag radials for $20, lol. Someone was moving and needed them gone. Yes they're dual lugs. The tires are a little too big for me (came off a 240) but still, $20 for a pair of wheels that I can mount slicks/drag radials that will fit isn't too bad.
Check ebay thats where I have seen them before.
By duesMANdella
#2009
You are the man, now im excited as i can have one set of rims for the b13 and b15 that i can put r compounds on
By xbrandonx
#2403
Here are some pics of my whole Nissan fleet. I couldn't take them at any hip spot other then my driveway because well, it's hard for me to move 3 cars, lol.
From left to right:
2.5, 1.6, 3.0
By Tonez
#2405
I think the 2.5 would be my favorite out of your fleet! :woot:
By KingDNH
#11493
What type of rear spoiler do you have?
By xbrandonx
#11881
KingDNH wrote:What type of rear spoiler do you have?
Don't recall the brand, but the brackets aren't the ones that came with it, it came with something like 8" brackets like you see the ones on ebay.
Search carbon fiber spoiler on ebay and you'll find some similar, just have to make some cheap brackets to mount it so it doesn't sit above the roof.
By tommymel
#74818
:thumbup: beautiful b15
By xbrandonx
#77099
hova04 wrote:ill give you another free bump. i know ive told you this on the other site but those wheels are beautiful! would they clear brembos?
100% sure that they DO NOT. Tried it on a brembo equiped car :(
