2007-2012
By powderohyeah
#244749
Engine:
Injen CAI
MR Header
MR Downpipe
Trubendz 2.5 inch Catback Exhaust with Flo-Pro 18” resonator and high flow cat
2JR lightweight crank pulley
Ebay Throttle body spacer
Uprev standard with a tune
Transmission:
Ralco RZ STS
Handling:
Ksport kontrol pro coilovers
MSS purple end links
Exterior:
C-Mod grille
Next for upgrades:
Hopefully turbo
Sent from my iPhone using Tapatalk
Last edited by powderohyeah on Thu Sep 07, 2017 10:10 pm, edited 15 times in total.
By powderohyeah
#244846
Finally got my intake installed. Excuse the dirty engine and rusted heat shield!
Headers and exhaust are next for mods!
By powderohyeah
#244852
yupp i sure did feel a difference! it always feels like my car just wants to stay at a high rev the whole time!
my headers came in today with the down pipe but still no midpipe and axle back
By eXcude
#244853
Nice. Yes I have noticed this engine loves being in the high RPMs. It loves it, I do too :D
You're almost there with the parts!
By eXcude
#244856
I've never installed a UDP. I've never seen any dyno charts proving any sort of HP/TQ gain. Just people saying they are awesome you should get one 'blah blah'
Clearly my opinion :D
#244858
just my opinion
if you use the car for sport
[read shift like mad]
then the stock dampener is the least cost best option
limits crank shock
for the light 2jr pulley
if just a DD,
i enjoyed the "feel" of quicker revs
and the slight improvement in stop and go traffic mpg.
[less mass to accelerate, decelerate per stop]
however,
for a real drag/track car
whats pictured works
required by the racing organizations listed on the front of the pulley
#244859
eXcude wrote:I've never installed a UDP. I've never seen any dyno charts proving any sort of HP/TQ gain. Just people saying they are awesome you should get one 'blah blah'
lol
i fixed it
they look awesomeif you show your car,should get one 'blah blah'
By eXcude
#244862
We got that balancer chain thingy too that you can cut, that allegedly add 10 HP. Don't have a lot of details about that. Honestly I/H/E is the best you can do w/out cracking the engine or scoping out a turbo. The other stuff you bolt in there doesn't make a huge difference for the cost IMO.
Feel free to correct me Yogi Dude :D
#245026
eXcude wrote:We got that balancer chain thingy too that you can cut, that allegedly add 10 HP. Don't have a lot of details about that. Honestly I/H/E is the best you can do w/out cracking the engine or scoping out a turbo. The other stuff you bolt in there doesn't make a huge difference for the cost IMO.
no corrections necessary
i spent more money getting to 187whp na
than 350whp turbo
please don't cut the chain on a dailly driver
i found the increase in vibs annoying
for very little power gain
yes, i run a bsr on the turbo motor, however, the rotating assebly is balanced meticulously
and i run a huge crank dampener
the motor is relatively smooth
for NA
a good intake
a good header and 2.5" exhaust
i didn't find a lot of power like that
but the sounds changed dramatically
a better one piece [i prefer steel esp for a DD] flywheel
quickens shifting up and eases shifting down
last would be mild cams and a tune
[2jr street, or jwt s1's]
this changes the feel of the engine
and makes for imo a very fun high revving engine
set up like this ,they are a joy in the mts or on an auto-x course
still needs a few things to be a really a fun track car, [coilovers, swaybars]
thats more money than you would expect
but
you'll get a very fun DD
esp if you do mostly highway driving
good sound, spirited performance and fun to drive
stop there or build for turbo
imo
imo
By powderohyeah
#245032
I think for me i will stick with I/H/E and maybe an ECU tune. There is a local shop in town that only does ECU tuning and maybe free up some more HP. But what good will cams do? does it give you more top end torque?
By powderohyeah
#245056
Everyone has probably seen this thousands of time, just thought i would post on my thread lol.
Finally got header in but didnt have time to install exhaust system. Doing that tonight after work.
#245062
powderohyeah wrote:I think for me i will stick with I/H/E and maybe an ECU tune. There is a local shop in town that only does ECU tuning and maybe free up some more HP. But what good will cams do? does it give you more top end torque?
cams change where the power comes in
and hi po cams shift max power higher in the rpm range
by increasing valve lift [size of the opening]
and duration [how long its held open]
hi po cams increase power
at higher rpm, by moving more fuel and air
more hp is developed
usually minor, in my case from 165 to 172
[supported by header, sri and no tune]
however the engine feel, from the drivers seat is completely different.
gone is the torquey truck motor
and you have what feels like, an old classic vette motor instead
at 5600 where the old motor fell off,
it now comes alive
and depending on crank and cams chosen, screams to 6500-7000 rpm
with rev limit extended,
and if no tune and uprev
makes the pull from 4600 to 6200 ecstatic
added to a fully bolted motor
the feel, sound, whole car changes in your experience
if you go by feel they are a great success
if by 1/8 mile times
not so much
imo
imo
10sec flat with just an sri
9.25sec plenum, race header, c1 cams, 3" exhaust, uprev tuned
built and turbo about 8 flat
built and cammed vq also about 8 flat
for comparison
can't seem to post pics or vid , at the moment
  • 1
  • 2
  • 3
  • 4
  • 5
  • 7
Yeah, yeah I know these cars can be problematic bu[…]
I have the 6 speed manual SR turbo and I've been s[…]
The Nissan Rogue appears to have big discounts at […]
Hi all I am kind of stuck and lost with a new Niss[…]
